Help with ricoh sg3110dn
Re: Help with ricoh sg3110dn
@Viccar - Windows 7 is essentially Vista fixed and improved - even the version number indicates this, it certainly runs a lot smoother on our computers (all of which are around 6 year old models)
newsgroupmonkey
Post by newsgroupmonkey »
I would concur with this. I'm running up Windows 8 on a couple of machines and I'm starting to think I may have made a mistake.
Windows 7 is everything Vista should have been. It's slick and it works. To give you an idea (by the way) of how the industry seems to have approached Microsoft Operating systems, the jury is still out on Windows 8......
Windows 98 Great
Windows ME Poor
Windows XP Great
Windows Vista Poor
Windows 7 Great......
So I'll leave it to you to decide about Windows 8
I'm learning. So I'm probably spouting rubbish. Be patient :wink:
Dave271069
Post by Dave271069 »
Don't sound great, as I just went out Saturday and treated myself to a £600 new pc with windows 8 . Hope it improves.
Temp solution, whilst waiting for Sawgrass to pull their finger out, would be to install just the Ricoh printer driver, and get custom ICC(s) made
Hi Dave271069
Is there anything else you can use to print your first test. Using a slate is a very risky move for your very first print from a printer that may not be supported using the operating system you are running.
If you have already tested then I admire your bravado :smile:
pisquee;60849 wrote:Temp solution, whilst waiting for Sawgrass to pull their finger out, would be to install just the Ricoh printer driver, and get custom ICC(s) made
Why would you want to get custom ICC profiles made? ICC profiles are already available from Sawgrass for the Ricoh.
Ah, I stand corrected, didn't realise they still had them still as separate options, thought it was power driver or nothing.
Dave271069
bms;60875 wrote:Why would you want to get custom ICC profiles made? ICC profiles are already available from Sawgrass for the Ricoh.
but sawgrass say not compatible with windows 8, does this mean my sub ricoh is no good with out a powerdriver? how much of a difference will it be? did a mug yesterday which was text only and it came out fine, the slate i did was passable but wouldnt want to do lots.
Dave271069;60880 wrote:but sawgrass say not compatible with windows 8, does this mean my sub ricoh is no good with out a powerdriver? how much of a difference will it be? did a mug yesterday which was text only and it came out fine, the slate i did was passable but wouldnt want to do lots.
Sawgrass says PowerDriver and Windows 8 are not compatible (yet). You can print from PhotoShop/ CorelDraw using ICC profiles. There are choices in the Windows environment. Mac users have to use ICC profiles only.
Dave271069
Sorry martin im a bit confused.
Look at my post on 1st page about 8th post i think, i took it from sawgrass site.it says powerdriver is not compatable! Which is right?
