iphone case woes
bigj2552
Re: iphone case woes
Post by bigj2552 »
anyone else getting this.
have had 3 iphone cases back now with the backings starting to come off - after only 1 DAY !!!
this looks bad for me, as it looks like shoddy products.
think i will need to put a spot of super glue at the four corners to give it extra hold :rolleyes:
AdamB
Post by AdamB »
bigj2552;59148 wrote:anyone else getting this.
Have you changed suppliers?
I only ask this as I used another supplier for (what I thought) was an identical (and slightly cheaper) product - only to find that they printed completely different!
bigj2552
Post by bigj2552 »
AdamB;59150 wrote:Have you changed suppliers?
NO...I only use 2 for phone covers adam.
still to early to pass any serious judgement ....yet.
just dam embarrassing when customers do this. but i rather find out NOW, than xmas.....that is a recipe for disaster, for business, and my reputation as a new store/seller :rolleyes:
but 4 tiny spots of super glue at corners should give me piece of mind :wink:
johnny
I've noticed that the glue on the cases isn't always perfect and can sometimes come away with the protective covering. The other thing I've started noticing is that it appears the surface of the aluminium inserts is peeling slightly at the edges...anyone else noticed this?
I noticed on the last batch I got that the printable surface did come away when i was trying to peel the protective plastic off them.
Also have noticed that covers from different suppliers/batches print very different - I can't afford the amount of iphone covers it would take to make an iphone specific ICC, especially as I already have a generic white aluminium ICC made!
I got some in from two different suppliers, Merlin Transfers and BMS.
Printed one using Merlin product and put it on my phone. Three days later the plate started to peel. Tried again with BMS and its still solid after three months.
BIGJ: Super glue will only work if it is the metal plate coming away from the adhesive and not the adhesive coming away from the plastic case. This is on the assumption that the adhesive is on the plastic case already and not on the metal. To ensure it sticks you would need to cut away some of the adhesive backing so that the metal is in direct contact with the superglue and the superglue is in direct contact with the plastic.
I hope that i have explained that correctly :smile:
bigj2552
Post by bigj2552 »
explains it perfectly bud :wink:
WorthDoingRight
Post by WorthDoingRight »
Always have my doubts about superglue and plastic cases - hopefully the cases are made with a plastic that superglue actually adheres to as if not you might need another type of glue.
Renniwano
Post by Renniwano »
I use BMS ones.. I had someone put mine through a 'real' life child/handbag (not mine, I don't do bags) test before even selling any of mine.. and they are all still on and doing fab.
bigj2552
Post by bigj2552 »
@ richard, for all it is bud, 4 wee dots at the corners. Hopefully it will do the trick......will tell you in couple of hrs.
got some more to do :wink:
