Sublimation Dark Transfer Paper
frazzle
Re: Sublimation Dark Transfer Paper
Post by frazzle »
I'm using a Ricoh SG3110dn printer. printing Dark Transfer Paper i set the printer setting to default (powerdriver) and printed a sheet out but the colour is a darker red than the original on my screen. Do i need to change any other setting to get the colour right.
[h=1][/h]
Ignore what is on the paper and try a sample press first.
The colours on a printed dye sub sheet always look dull/faded and totally incorrect, but transfer perfectly
frazzle
Post by frazzle »
OK will give it a go thanks for quick reply.
WorthDoingRight
Post by WorthDoingRight »
I know it is possible to use sublimation inks on dark transfer paper but really this type of paper is for standard pigment ink such as Epson Durabrite and therefore I would doubt you will get the results you want this way.
frazzle
Post by frazzle »
Panic over come out spot on thanks for your help.
