white on black
Re: white on black
Not with sublimation! You could print black full wrap and get the white text that way otherwise you could use one of the black mugs with a white panel but getting the panel all black to match the mug properly isn't easy.
Or.....you could use transfers or screen print.
Re: white on black
screen print, or reverse text by sub
Re: white on black
or you could sandblast the black layer off using a stencil to reveal the white ceramic under the colour layer and then seal it with some krylon.
- WorthDoingRight
Re: white on black
Is Krylon similar to Rustoleum?GoldRapt;57431 wrote:or you could sandblast the black layer off using a stencil to reveal the white ceramic under the colour layer and then seal it with some krylon.
