white on black
frazzle
Re: white on black
Post by frazzle »
How would you print white text on a black mug?
Re: white on black
Not with sublimation! You could print black full wrap and get the white text that way otherwise you could use one of the black mugs with a white panel but getting the panel all black to match the mug properly isn't easy.
Or.....you could use transfers or screen print.
logobear
Re: white on black
Post by logobear »
screen print, or reverse text by sub
GoldRapt
Has thanked: 6 times
Been thanked: 8 times
Re: white on black
Post by GoldRapt »
or you could sandblast the black layer off using a stencil to reveal the white ceramic under the colour layer and then seal it with some krylon.
regards
Tony
-launching july/august 2026
WorthDoingRight
Re: white on black
Post by WorthDoingRight »
GoldRapt;57431 wrote:or you could sandblast the black layer off using a stencil to reveal the white ceramic under the colour layer and then seal it with some krylon.
Is Krylon similar to Rustoleum?
Re: white on black
I dunno but you got Superman worried.
GoldRapt
Re: white on black
Post by GoldRapt »
hahaha
Yes sort of, you get krylon clear in b&q
regards
Tony
accdave
Re: white on black
Post by accdave »
frazzle;57411 wrote:How would you print white text on a black mug?
White Chalk :)
