Help Wanted asap please
Re: Help Wanted asap please
Hi All, i use coreldraw x5 for all things i do and i recently designed a 8 page brochure for someone, I was asked to send it to them in pdf which wasnt a problem and they loved it, Now i have the problem of them sending it on to get printed in time ready for the dirt bike show, I got in contact with the company who are doing it and they said to send it direct to them in pdf form and in prepress mode so they could print it, so after a hour or so of sending it page by page due to being to large to send they have now said it wont work because they use adobe and this was the message i got back
"files that are going to print need a bleed around the edge the document also has to be the correct size kirk wants these A4 so would be 297 x 210, in illustrator its in doc setup you can size and put a 5mm bleed on all edges then when you save it as a PDF say use doc bleed settings and tick all print info/marksthen this will be ready to go, being a PDF i cant do it myself, i would if they were EPS files but may be to big to send, try it as an EPS though if you like and i can sort it out just make sure all fonts are outlines and not fonts.
Could some one please advise me and help me to sort this out if you know how to as im i stuck
Many Thanks
Adam
Many Thanks
Adam
On X3 there is the facility under 'export' to save it as an eps file. Don't know if this is on X5 but would suspect it is there. If it is all he has to do is import it into his software as text.
Thank you Roger, i will have a look now and try it my self before i phone and tell them
Earl Smith
I thought of that idea but the company who are going to do them have agreed to meet half way and pay petrol, Thanks you both for ideas and Roger i done what you said and they were still to bog to send
- WorthDoingRight
If this is going to be a regular thing for you then you need to consider one of the large file transfer services or as ES has said a service like dropbox.
Click on PUBLISH TO PDF
Select PDF FOR PREPRESS
Click on SETTINGS
Click the PREPRESS tab
CHECK the box at the top that says BLEED LIMIT and adjust to 5mm
Click on CROP MARKS & REGISTRATION MARKS
Click OK
Click SAVE
EMAIL FILE
MAKE A CUP OF TEA
POST THREAD TO SAY THANK YOU
Click on SETTINGS
Click OK
Click SAVE
EMAIL FILE
MAKE A CUP OF TEA
Earl Smith
Thank you Social
, Got it all sorted now but i used this method to convert them my end just in case i need to send else where
socialgiraffe;57155 wrote:Click on PUBLISH TO PDF
Click on SETTINGS
Click OK
Click SAVE
EMAIL FILE
MAKE A CUP OF TEA
