I'm not perfect & would never try to tell people I'm perfect but, I will always try to achieve perfection in what I produce. Remember sarcasm can be the lowest form of wit.WorthDoingRight;53832 wrote:Ian of course we can all see what you write - we just can not comment on perfection :rolleyes:
First time buying a printer for sublimation mug printing
Re: First time buying a printer for sublimation mug printing
- WorthDoingRight
Then it should be easy enough for an educated man, like yourself, to identify in conversationIan M;53837 wrote:Remember sarcasm can be the lowest form of wit.
coolkidirish
I'm new to the site and everyone told me SG3110DN would be best option by Rioch
Hi Coolkidirish
You are right. that Ricoh is the best option unless you need to print A3.
Become a premium member for £10.00 then purchase from BMS and get a DSF members discount. Quids in!
coolkidirish
i am now a premium membersocialgiraffe;57033 wrote:Hi Coolkidirish
The Ricoh is the way to go , great printer and does not clog up as easily as other printer if you are not using it a lot.
Regards Ian & Andrea
The only failure, is the failure to try.
carter2
I will suggest Ricoh..Great device with very good quality of printing and easy manual guide:)
