Owners of Ricoh 3300n sub printers - please read
Re: Owners of Ricoh 3300n sub printers - please read
All appeared clear to me. I reckoned on 6 logos per sheet of A4. Hence 100 sheets. But if way are saying 300 sheets then I'll add £32 to my estimate
Hence £112 for ink and paper.
Janners
Janners
yes we were hoping but with a bleed area it just doesnt fit.JMugs;47802 wrote:All appeared clear to me. I reckoned on 6 logos per sheet of A4. Hence 100 sheets. But if way are saying 300 sheets then I'll add £32 to my estimate
Janners
Sounds like a good way of making a simple job comlicated, i just allow £2 per A4 sheet for ink and paper, e.g 3 mugs to a sheet works out 65p per mug + 80p for the mug, total £1.45. If i had to worry about a few quid for ink and paper, then i'd find another job, ink and paper costs are not even worth bothering about, if you are getting a good price for the job in the first place.
You know what. I think I'll keep what I have found to myself. The post was aimed to help people but its just not worth it. I despair.
GSTK,
please don't dispair, please share what you have found out, pricing big jobs is always difficult, I tend to price time, almost ignor material cost, but I don't know what I am missing. what do you think?
I'd be interested to hear, not that I use a Ricoh or Sawgrass ink, but I tried doing cartidge weighing a while back to work out my costs per print, but in the end figured my scales weren't accurate enough for the small changes in weight in the cartridges.
- WorthDoingRight
LOL, at least some of us tried to work out an answer whether we owned the Ricoh or not. Trouble is we all can research that a cartridge contains 29ml of ink and costs £48 making it £1.66 per ml. The issue is knowing how much ink the printer uses per page at the amount of coverage stated.gstk;47839 wrote:You know what. I think I'll keep what I have found to myself. The post was aimed to help people but its just not worth it. I despair.
Researching further would suggest it is agreed that the cost for the ink per sheet is 25c based on a cartridge costing $68.50 which is equivalent (at a uk price of £48 a cartridge) of 17.5p per sheet for ink alone. Therefore if we ignore all other costs the ink alone should cost £52.50.
I therefore now believe that you might have asked this question having gotten exactly 300 sheets out of a single cartridge
This job is all black, so does this mean it will use about 1 cart of black, - will the printer print CMYK black - so will also use up 1 each of the other carts too ?
Well I will say research is categorically flawed. As they say don't believe what you read. A lot of people will be working at a lossWorthDoingRight;47850 wrote:LOL, at least some of us tried to work out an answer whether we owned the Ricoh or not. Trouble is we all can research that a cartridge contains 29ml of ink and costs £48 making it £1.66 per ml. The issue is knowing how much ink the printer uses per page at the amount of coverage stated.
Users browsing this forum: Amazon [Bot] and 5 guests
