Ricoh Carts 3300
gstk
Re: Ricoh Carts 3300
Post by gstk »
If you have seen my other post in printing about the Ricoh (please view if you have a few mins) A fill Ricoh Black cart is 92 gram full and 62gram supposedly empty. They never fade so I am fairly sure it is software driven to tell you when its empty. Anyone found a way of ressetting the carts?
Cheers
Tony
JMugs
Has thanked: 9 times
Post by JMugs »
If you are referring to the sawgrass ones then allegedly they cut out as a result of a vacum prompt, the theory being that it will run until totally empty. If any other cartridge then I have no idea.
Hope that helps.
Janners.
gstk
Post by gstk »
JMugs;47809 wrote:If you are referring to the sawgrass ones then allegedly they cut out as a result of a vacum prompt, the theory being that it will run until totally empty. If any other cartridge then I have no idea.
Hope that helps.
Janners.
ALLEGEDLY - Thanks
gstk;47804 wrote:If you have seen my other post in printing about the Ricoh (please view if you have a few mins) A fill Ricoh Black cart is 92 gram full and 62gram supposedly empty. They never fade so I am fairly sure it is software driven to tell you when its empty. Anyone found a way of ressetting the carts?
Cheers
Tony
Why do you want to reset if the cartridge is empty?
gstk
Post by gstk »
Because I'm not convinced Its empty. I will break an empty open tomorrow
It won't be completely empty, it stops short of being empty of the printer will end up sucking air into the lines/head (assuming the Ricohs work similarly to Epsons)
gstk;47840 wrote:Because I'm not convinced Its empty. I will break an empty open tomorrow
We have a large number of gxe3300 genuine carts which are £10 per set. If there is indeed ink inside then buy a set of genuine carts (discounts for multiple sets) and use the new chips...
pisquee;47843 wrote:It won't be completely empty, it stops short of being empty of the printer will end up sucking air into the lines/head (assuming the Ricohs work similarly to Epsons)
Depends how they work. They are bagged inside the case so you can't suck air - so either they are vacuum triggered or it is based on the chip.
gstk
Post by gstk »
it will be interesting anyway to see the inside anyway.
JMugs
Post by JMugs »
I knew I had seen it somewhere.
Skip to 18.50m on the video.
http://www.youtube.com/watch?v=0dSnBXDIm3A
