carrier sheets
sarahjayne
Re: carrier sheets
Post by sarahjayne »
I need to cut 2 sheets of A3 card - I looked at the cameo carrier sheets but with postage it will cost me £20 and wondered has anyone any ideas how I could DIY one as it's just for this one off.
I thought of an A3 card with a sheet of sign application tape spary glued to the top of it ( as I have these already) - any idea if it will work or what I can use instead?
cheers
SJ
mrs maggot
Re: carrier sheets
Post by mrs maggot »
how about those plastic thin place mats ? they are about the same thickness as a carrier sheet
mgibbs
Re: carrier sheets
Post by mgibbs »
letsgo
Re: carrier sheets
Post by letsgo »
How about the carrier backing from t shirt flex as most have a tacky glue to hold the cut out lettering and logos before applying to garments
hidehi
Re: carrier sheets
Post by hidehi »
Not exactly a DIY suggestion, but I've heard you can use the Eclips carrier sheets. I saw them in Hobbycraft at the weekend...£7.50 for two so much cheaper than genuine cameo ones.
JackB
Re: carrier sheets
Post by JackB »
Card and double sided tape.
Jack.
