Hi
I've just wasted some wallets, when I print it stll leaves some white marks on one it looked liked creases, I tried it with and without a silicon mat pushed into where the notes go and I used the correct time, heat and pressure recomended by BMS but they are not sellable, does anyone have any tips.
Thanks Bob
Printing Wallets
Re: Printing Wallets
i always pre press my for few seconds then print them at 185C 60sec. heavy pressure. never had a problem
Thanks Paul I'll give it a go, do you put anything in the wallet to lift the printable area
nope. i put my on the edge of my press. only printable bit. re press it and press it with transfer on.
Good man, I'm inspired again
I use to place a folded towel under mine when pressing. Just put the flap under the press on the towel. This allows any press studs etc to sink into the towel giving a flatter printable area. High pressure.
