My first rocks slate (and just for bin)... :)
michallatal
Re: My first rocks slate (and just for bin)... :)
Post by michallatal »
Hi,
I have tried to press first rock slate (Coralgraph), pre-heat for minute even with silicon pad, then press face up for 7 minutes at 190 degrees and result?
Have a look?
Any advice, where is problem?
Thank you
Michal
[ATTACH=CONFIG]867[/ATTACH]
btw. picture is done a few minutes under room lights and without flash. :)
vB_ID:867
vB_ID:867
Personalised gifts and products
<a target="_blank" href="http://www.owngifts.co.uk/">http://www. ... .co.uk/</a>
Whats wrong with this one? On mobile look ok :-)
michallatal
Tomorrow on computer you will talk different, trust me... :) I put original as well.
[ATTACH=CONFIG]868[/ATTACH]
vB_ID:868
vB_ID:868
JackB
Post by JackB »
What pressure?
It looks like to light a pressure on the bottom right corner especially.
Jack.
Imme
Post by Imme »
It looks like either the pressure was too light or the image wasn't fully dry on the paper before pressing.
I have seen some blotching like this when the image is taken out of the printer and placed straight onto the slate.
We try to preheat the image under the press for a couple of seconds if it is needed urgently.
As for the Coralgraph slates I think they are great, they work really well with a sepia image. Here's one we did earlier.
[ATTACH=CONFIG]869[/ATTACH]
Was it a shotgun wedding?
vB_ID:869
vB_ID:869
JackB
Post by JackB »
Try a higher constant pressure. We had a problem with the photo panels, the press would not lock because of the thickness of the panel, and a firm constant pressure was not being applied. a constant pressure solved it.
Jack.
michallatal
Thank you guys, probably I have been to scare to destroy stale, that it was more low/medium pressure.
So I will try to preheat image for a few second, make sure it is dry and I will not be scare to do high pressure.
Second test tonight, I will try same picture to see result. I will let you know.
low/medium pressure is right for slates.
but also pre heat image for few sec would be good. hover you press over image. this should dry it up a bit. how thick is your silicon sheet?
michallatal
if you remember, silicon sheet is same as you have got... :smile: How I said I am going to try tonight and send image of result.
Now I have to go with little one on Post office to send some products (not Rock slates) :wink:
ohh. i know one you own :)
good sheet!
