horizontal lines help
Re: horizontal lines help
When I print with my Ricoh GX5050N, I'm getting thin horizontal black lines about 1cm apart, even on a nozzle check it's fine apart from a thin black line through the middle of the colour blocks.
Any ideas? I'm stumped.
Gordon
Gordon
I get them. and I do a couple of cleans then test print, have you tried that,
Have you tried the head alignment?gorgall2;41232 wrote:When I print with my Ricoh GX5050N, I'm getting thin horizontal black lines about 1cm apart, even on a nozzle check it's fine apart from a thin black line through the middle of the colour blocks.
Gordon
- Has thanked: 13 times
- Been thanked: 12 times
Any chance of posting a pic? Do you get other horizontal lines in-between or just these? Have you checked the paper adjust/feed setting?
Head alignment and paper adjust/feed setting both fine. I've tried more head cleans, this seems to make some of the lines disappear for one clean only to reappear on the next.
[ATTACH=CONFIG]866[/ATTACH]
these are the lines
these are the lines
- vB_ID:866
- img006.jpg (114.56 KiB) Viewed 794 times
Could they be ink on the transfer rollers type wheels that guide/pull the paper through the printer.
What's the size of the Ricoh printhead? If it's 1cm, then that could be a broken printhead that has one of the black nozzles constantly firing.
It's just a thought. I don't own a Ricoh but I'm fairly sure I've seen something similar before when the line was across the page and the same distance as the size of the printhead.
