horizontal lines help
gorgall2
Re: horizontal lines help
Post by gorgall2 »
When I print with my Ricoh GX5050N, I'm getting thin horizontal black lines about 1cm apart, even on a nozzle check it's fine apart from a thin black line through the middle of the colour blocks.
Any ideas? I'm stumped.
Gordon
jennywren
Post by jennywren »
I get them. and I do a couple of cleans then test print, have you tried that,
gorgall2
Post by gorgall2 »
First thing I tried,
gorgall2;41232 wrote:When I print with my Ricoh GX5050N, I'm getting thin horizontal black lines about 1cm apart, even on a nozzle check it's fine apart from a thin black line through the middle of the colour blocks.
Gordon
Have you tried the head alignment?
Has thanked: 13 times
Been thanked: 12 times
Any chance of posting a pic? Do you get other horizontal lines in-between or just these? Have you checked the paper adjust/feed setting?
gorgall2
Post by gorgall2 »
Head alignment and paper adjust/feed setting both fine. I've tried more head cleans, this seems to make some of the lines disappear for one clean only to reappear on the next.
gorgall2
Post by gorgall2 »
[ATTACH=CONFIG]866[/ATTACH]
these are the lines
vB_ID:866
vB_ID:866
John G
Post by John G »
Could they be ink on the transfer rollers type wheels that guide/pull the paper through the printer.
gorgall2
Post by gorgall2 »
I don't think so, as they go across the paper not down it.
JSR
Post by JSR »
What's the size of the Ricoh printhead? If it's 1cm, then that could be a broken printhead that has one of the black nozzles constantly firing.
It's just a thought. I don't own a Ricoh but I'm fairly sure I've seen something similar before when the line was across the page and the same distance as the size of the printhead.
