whats an extra few cm's
bigj2552
Re: whats an extra few cm's
Post by bigj2552 »
John G;40246 wrote:I've both types and think the swing away is the best option for me - but, you do need extra space to, swing it away :wink:
take it the clam version is only good if the head is NOT fixed ?---(top centralised pressure)
mrs maggot
Post by mrs maggot »
a clam, you can position the garment front or back and side to side, i have just done 20 formula1 style race shirts for a company, each with 10 designs on, most of them multi layered, and its a 38 x 38 no issues.
sometimes its you simply put the garment on neck out and feed it over the plate so the "extra" is in front if that makes sense, but i dont know why you think you would burn anything ??
bigj2552
Post by bigj2552 »
mrs maggot;40250 wrote:a clam, you can position the garment front or back and side to side, i have just done 20 formula1 style race shirts for a company, each with 10 designs on, most of them multi layered, and its a 38 x 38 no issues.
if doing thicker garments like hoodies / fleece's ect.....
if the plate is fixed at top - your not gonna get an even pressure when you pull it down....correct me if i,m wrong..please :-)
just trying to get my head around all this before i buy !
mrs maggot
you open the garment up and put it on the press bed, like thats the body so only one layer is under, the clam then closes on it - think toasted sandwhich maker - the pressure thats on the press pulls it down to a very even pressure
bigj2552
Post by bigj2552 »
mrs maggot;40255 wrote:you open the garment up and put it on the press bed, like thats the body so only one layer is under, the clam then closes on it - think toasted sandwhich maker - the pressure thats on the press pulls it down to a very even pressure
ah....thanks laura.....
in your opinion - clam / swing and/or combo with £500 budget ?
John G
Post by John G »
That's the one I bought, but if I had the money I'd by a better one from a reputable company, not lovecut.
http://www.lovecut.co.uk/heavy-duty-15x ... -386-p.asp
The press works and is value for money compared to some of the crap out there, but there has been quite a few problems from the word go.
Cheers John
AdamB
Post by AdamB »
John G;40258 wrote:That's the one I bought, but if I had the money I'd by a better one from a reputable company, not lovecut.
http://www.123-reg.co.uk/support/answers/how-do-i-set-up-my-dns-for-web-forwarding-2526/
Cheers John
That the wrong link there old man?
(sorry - coucldn't resist that)
mrs maggot
BigJ, if you are only doing t shirts, then not a combo - why would you need, but if you are planning on doing caps/mugs etc then a combo is a good idea, and then replace it when a better press comes up 2nd hand (or you have funded a new one) the combo can always be kept as a back up for all your other equipment.
I have a geo knight press, had great backup from them recently, but it depends on how much you want this press to do
John G
Post by John G »
Don't know what you're talking about son! :wink:
Yes, made a boob and then corrected.
:redface:
bigj2552
Post by bigj2552 »
mrs maggot;40263 wrote:BigJ, if you are only doing t shirts, then not a combo - why would you need, but if you are planning on doing caps/mugs etc then a combo is a good idea, and then replace it when a better press comes up 2nd hand (or you have funded a new one) the combo can always be kept as a back up for all your other equipment.
will be doing caps and mugs laura.....
seperate flat press and mug press is way i want to go but.
i dont fancy paying another £200 just to get a cap press !!
so.....combo it looks like....
38x38 big enough for most jobs i take it ?
