d120 help power flashing,red ink light on
Re: d120 help power flashing,red ink light on
hey there, im new to dye sub so dont know much,i have a epson d120 . i have been using it to do some mugs . the problem is that the power light is flashing when i go to print and the red light is staying on,which i believe is the ink?
can anyone help me with this i think it needs ink, but there seems to be ink in all chambers ,though the 2 black 1s are a bit low, 1 is lower than the other.
could that be the problem?
Is it not flashing because your waste ink tank is full? Can you move your cartridges to change cartridges position?
paul i think you have cured a hangover!! done that and made out to printer there was a new cartridge inserted and all was solved!!
well for the now anyway cheers mate!!!!!!!
your a star!!
am gonnae need ink anyway at some point where is best to get it? i dont want cheap, i want qaulity !
thanks again
your a star!!
thanks again
well i thought it was cured but seems to be false., it turned ot it only printed twicr good then back to same, then,,,,, i ended up breaking the green and white thing on top of the ink cartridges
which i guess is a sensor of some sort?
i guess this is gonnae be a big problem now???????????????
The problem sounds like it is the cartridge block that is not fitted into the cartridge holder properly. This is a FIRM insertion and if the chips are not making proper contact then this light sequence will show.gonzo;30760 wrote:hey there, im new to dye sub so dont know much,i have a epson d120 . i have been using it to do some mugs . the problem is that the power light is flashing when i go to print and the red light is staying on,which i believe is the ink?
The breaking of the upstand on your cartridge block is terminal though and you will need to purchase a replacement cartridge and tube assembly from your supplier for your printer.
The breaking of the upstand on your cartridge block is terminal though and you will need to purchase a replacement cartridge and tube assembly from your supplier for your printer.[/QUOTE]
can you please tell me where i can get this from and how much it will cost ? thanks
boristrump
best to look up ebay for a epson d120 going for spare and repairs
A new D120 won't help as it is the cartridge block of the EasyFlow system that is broken.boristrump;30803 wrote:best to look up ebay for a epson d120 going for spare and repairs
gonzo;30799 wrote:The breaking of the upstand on your cartridge block is terminal though and you will need to purchase a replacement cartridge and tube assembly from your supplier for your printer.
can you please tell me where i can get this from and how much it will cost ? thanks[/QUOTE]
You will need to get the correct cartridge and tube assembly from a Sublimation supplier. I presume you are using Artainium ink? The RRP for the new cartridge and tube assembly (which comes filled with sublimation ink - around 60-75ml of ink) and connects to the bottles (where the lock nuts are in the tubes) is around £50 +vat. Speak to your original supplier though as they may be able to help with a goodwill gesture!
hi martin thanks. for your help, to be honest i bought the printer from a guy i worked with he sold me it as he was moving back down south. i have tried getting in contact with him but to no succes .
i dont even know what ink is in it :redface:
would it be better if i just bought a new ciss system if i dont know what in is in it?
i have been looking at them but there going to cost nearly £300 from sawgrass.
Users browsing this forum: Google [Bot] and 6 guests
