really! that shouldn't happen should it???R.Prints;29537 wrote:..... and after a short period of use as a key ring the imagestarts to scratch off. Good for a short life gift.
xpres keyrings
Re: xpres keyrings
Re: xpres keyrings
Obviosly i know there wont be any white on it
my only problem is that after pressing on them their aint shiny as their where before. I will try take the photo of the problem...
Re: xpres keyrings
Have you rubbed it gently with some water Paul to make sure it not paper fibres that have been left on the surface?
I only say this as it looks similar to when I had the 'slate problems'.
Re: xpres keyrings
yep. i tear all paper of the coating in the sink. this look more like sandpaper tear
i know is somethinkg to do with preasure. this same with lighters. lighter preasure=less blemishes. so use almost non preasure now. its definitly not problem with my plate as it happen when cover with teflon or uncoverd.
Re: xpres keyrings
do you think your problem might be that you are buying indirectly, hence have no idea on the quality of the product?
i followed the instruction and it just worked, not found much interest in them thou......
Re: xpres keyrings
i dont think this is lack of quality buddy. as it hapend to me every time i press lighter too. and I had them from load diferent sources. Is worth to mention it happend to me couple of times when I pressed mirror silver busines cards too.
Re: xpres keyrings
Are these from the same source - as logobear has mentioned, if you buy from third party there's no come back - buy from the supplier (not ebayer) then you can always go to them for support.it happend to me couple of times when I pressed mirror silver busines cards too.
swimwivsquid
Re: xpres keyrings
Paul, I found that the paper made a difference. I tend to use Texprint HR for metal keyrings as the Jet Col paper, which is the other paper that I have, prints terrible on them.
Re: xpres keyrings
no. not same source. and whats the third party this days?? all come from china
I had some silver from reputable suppliers that are members of this forum and it was this same problem. ALways mirror silver. I think this i down to me
I must do something wrong...
