If your worried about the resolution this design could be replicated in coreldraw in a few minutes - it looks just like squares of colour to me.
Paul's got a point - why advertise when you cannot print mugs successfully yet - practice makes perfect, if you cannot do full wraps I wouldn't be advertising them!
Printing problem....?
Re: Printing problem....?
TPM;21132 wrote:Interesting....now Ive turned the paper over to rougher side up in printer tray, the printed mage is a lot more vibrant on the paper..... before it prints quite dull.....now to press it....!
Do you have the Ricoh printer? If so then the paper goes in the tray face DOWN so it prints on the brighter White side.
What I mean by turning the mug round is, if you start with the open end of the mug facing you, turn it so that the base of the mug is facing you.
Thanks all - problem solved!
Regards advertising - I have sold a few - no complaints - I would never send anything to anyone that didnt look good or the customer wasnt satisfied with..... I might be new to sublimation, but not to customer service
Thanks again for all your help
problem solved? is this mean you printed on wrong side??
[ATTACH=CONFIG]205[/ATTACH][ATTACH=CONFIG]206[/ATTACH]
The wrong side (I also discovered one of the kids had been using paper from that tray to draw on
!!!!!!) hence the wrong way round!
I adjusted the pressure - again...
I swopped the mug around half way through - great tip!
- vB_ID:206
- mugs 081.jpg (90.57 KiB) Viewed 11 times
- vB_ID:205
- mugs 080.jpg (92.34 KiB) Viewed 11 times
- mugs 081.jpg (90.9 KiB) Viewed 11 times
- mugs 080.jpg (92.72 KiB) Viewed 11 times
