Printing problem....?
Lee
Re: Printing problem....?
Post by Lee »
Hi there
I am printing a mug, but I'm not happy with the results in 2 areas - its a full wrap, multi coloured - if you imagine a patchwork quilt it wouldn't be too far off....
Problem 1 - I notice one bottom corner is a bit faded... I've printed this twice now and the second time I made 100% sure it was positioned right and completely flat and sealed with heat tape - altho there is a white edge protruding from the image..
Problem 2 - I notice the black isn't 100% solid really...?
I am printing at 180 for 150 seconds...
Also...the image was supplied as dpi of 72 - so I have changed this to 300 - I presume this loses a bit of quality - or is there another way to effectivey adjust an image in PS...
Thanks again!
John G
Post by John G »
150 seconds is too short try 180 @ 180 seconds. Faded is either not enough time or not enough pressure. Try adjusting the seconds and if no good put more pressure on.
Lee
Post by Lee »
Thanks John - will do!
Kaz
Post by Kaz »
If I get white fading on the edge of a print, I turn the mug round in the press and press again for about 60 secs, that usually cures it.
And as John says, try 180 secs
smitch6
Post by smitch6 »
i had thought of doing that Kaz but wasn't sure if it would burn the rest of the image?
i often get the edges esp near the handle that are more faded and it's really annoying so this tip would be really handy and maybe another one of those facts for Justin section :)
Kaz
Post by Kaz »
I think it's just down to the blanket being cooler round the edges.
I've actually got into the habit of turning the mug half way through cooking time to ensure it doesn't happen again, lol
Lee
Post by Lee »
[ATTACH=CONFIG]203[/ATTACH][ATTACH=CONFIG]204[/ATTACH]
These are the mugs so far.....I think this one is going to cost ME money :-\ Could thi be that the image quality was sent to me as 72dpi - internet quality, not print quality - although I did adjust it...
When you say turn the mug - how so? The DF1 closes around the handle space at the top - I cant understand how I could print it in a different position...
The cust wanted full wrap, I may have to reduce the size to show some white edges top and bottom and more near the handles, hopefully this might avoid the fade...?
Should I be refusing jobs that aren't at the right dpi - as my adverts state - and ask them to resend better images.... but I dont want to lose what little business Im currently picking up....!
Headache!
vB_ID:204
vB_ID:204
mugs 079.jpg (94.83 KiB) Viewed 38 times
vB_ID:203
vB_ID:203
mugs 078.jpg (104.2 KiB) Viewed 38 times
mugs 079.jpg (95.19 KiB) Viewed 38 times
mugs 078.jpg (104.55 KiB) Viewed 38 times
first of all there is no such a thing like "adjusting image from 72dpi to 300dpi" you can change the settings but it wont impove image at all! if this would be so easy then photographers would not buy expensive cameras with lot of megapixels.
second. it all look like not enough pressure or I had similar when i printed on wrong side of sublimation paper. are you sure you printed on right side???
third:
I would not advertise till i master it a bit more. if you get customers and start to mess with the mugs etc... you may loose your reputation on start. so is good to practice first...
Lee
Post by Lee »
Thanks Paul - I'll try again - I have bumped up pressure already, and other mugs I have completed are fine - it just seems to be this image thats has been sent to me...which is why I was questioning quality of the image... The paper is loaded in the printer shinier side up - Im going to turn the top sheet over and try that!
Watch this space!
Lee
Post by Lee »
Interesting....now Ive turned the paper over to rougher side up in printer tray, the printed mage is a lot more vibrant on the paper..... before it prints quite dull.....now to press it....!
