craft robo and a printer conflicting
jenthelemur
Re: craft robo and a printer conflicting
Post by jenthelemur »
Hi,
I installed a printer on my computer and ever since this the craft robo won't work - having a panic as i need to finish some things off.
I don't get it as its on a different usb the other printer is turned off - baffled
The craft robo makes his little waking up noise when you go to the output panel just comes up with an error when you press cut :(
Hve you checked the port settings for both items?
jenthelemur
thanks, yes the robo is on usb1 and the printer usb3 and they are saying that in the settings - the robo was a troublesome devil to set up in the first place :( i don't understand why it won't allow any other printer on there.
noobie_uk
Post by noobie_uk »
Might be worth re-installing the robo drivers again? Just a thought...
Users browsing this forum: Amazon [Bot], Semrush [Bot] and 3 guests
