MH-721 Cutter - Communication Problems?
- mrs maggot
Re: MH-721 Cutter - Communication Problems?
i never cut through corel justin i always put it through cutter software, i have never achieved the same quality of cuts
Same - design in coreldraw and export then import into artcut. Long way round but works and never really got it working well when cutting from coreldraw
funny thing is when my cutter cuted those silly line through the designe it was whn i used corel tooo :/ flexi and coupleother programs work perfect.
- Has thanked: 11 times
- Been thanked: 9 times
It was cutting perfectly from cdraw before so I need to retrace my steps!
OK, finally got a decent size job in and had a few problems setting the cutter back up again. I can get it to cut through Flexisign so I should get the job done. Easycut is crashing when I try to import my .ai or .eps file
Could really do with cutting direct from Coreldraw to make life easier. As mentioned previously, I did have it working A1 in CD but now it appears to be sending scrambled messages and not cutting properly.
