How to?
Re: How to?
How can I get this jpeg converted so the Craftrobo will cut it onto vinyl?
It looks like allot of weeding to me!
[ATTACH=CONFIG]139[/ATTACH][ATTACH=CONFIG]139[/ATTACH]
Also If I want to put vinyl onto magnetic strips, what is the correct vinyl for this?
- vB_ID:139
- SkitzoLogoRevised1.1.jpg (73.24 KiB) Viewed 337 times
- SkitzoLogoRevised1.1.jpg (73.6 KiB) Viewed 337 times
Re: How to?
what software do you have?
hardly any weeding there
Re: How to?
Sorry if I sound stupid, but what do I do with the file. The Robo master software will not read it.
Re: How to?
right ;( you can open it with corel or illustrator. Also you can cut it via corel too.
Re: How to?
Trying to upload an eps that's easily cutable but its saying file invalid.
If you have coreldraw do a simple or quick trace, delete the background, trim the white onto the black, delete the white then weld the rest. Export as an eps then import the eps into your cut program.
Bobs ya auntie!
Bobs ya auntie!
Re: How to?
I did upload eps one John! but unfortunatly CR wont read it
Re: How to?
I can see your eps Paul but its a little pixelated to cut directly - i've done an eps file that's simplified but cannot upload it. Is there any way to upload an eps file - how did you do yours.
Re: How to?
Sorry Paul, just checked your eps again - it could be because there's a faint background that could be confusing the CR. Take that off the it might be usuable.
Cheers John
Cheers John
