Epson B1100 custom profile.
Re: Epson B1100 custom profile.
what you mean by "up the res"??
increase the resolution
like i did with that image i sent you
it was about 70 orginally and i upped it to 300
but kept the size the same
you know that this wont work do you? you just made the file waight more but quality is not any better
any way... how you getting on with this trial PS??
i've not done it as its the wife's work lappy
she has only just got home and will be using it most of the eve
um no lol
now googling how to improve the quality lol
from the results i've found i do all of that anyway
but when i get a good quality image like this one i don't usually need to
um no lol
can you edit your pot
will be easyer to read them
Thanx
Thanx
Just of topic can't isn't there a PC emulator for the Mac you could try.
Ride it like you stole it shiny side up.
Smitch. I printed a mug miut a go. just to show how big diference make paper u use.
here you can see this same mug with same designe. both printed in this same press on this same settings ie. time and temp. also both of them was printed with this same printer B1100 useing one profile:
please accept my appology for blured picture but it was only for quick snaps so did not used my light and softboxes
ok thanks paul
i bought the trupix though and assumed its highly recommended
the second one is really grainy which is how all my images come out like even with the trupix paper
what paper did you use for the better one
thanks steve
thanks steve
i use texprint. I use it for everything. fabrics and ceramics.
Might be a daft question but are you using the correct side of the paper?
