Wide format fastest print and cut?
JMugs
Been thanked: 12 times
Re: Wide format fastest print and cut?
Post by JMugs »
Just having a coffee (perhaps too strong?) and had a thought. What is the fastest sublimation printer for mugs? Mugs only because that is a lot of cutting.
Is it a small desktop loaded with mug paper? Is it a wide format?
Am I the only one that has these random thoughts? Perhaps I should have less coffee!!:wink:
Janners
GoldRapt
Has thanked: 7 times
Post by GoldRapt »
Great question, i have similar random thoughts, are you drinking Nescafe, black or that starbucks type crud?
regards
Tony
-launching july/august 2026
JMugs
Post by JMugs »
"Nescafe, black or that starbucks type crud?" ohh you made me shudder then.:biggrin:
Cornish coffee "Colombian Smooth" is the current roast.
Brewed in a "French Press"
A dash of oat milk just to lift the flavour
22g of coffee, 330ml of water, 5 minute brew.
GoldRapt
Post by GoldRapt »
I imagine the size of printer thats best, based on you question, comes down to available space and volume of sales.
columbian coffee?
regards
Tony
Has thanked: 13 times
We find printing onto mug sized paper saves a lot of time. That said, the quickest way would be to get someone else to do them all! Happy to work with anyone on this ;-)
Tried the wide format option and it's not much use. If you have a cutter that will automatically cut the mug templates that could work,
JMugs
Post by JMugs »
Justin;155138 wrote:We find printing onto mug sized paper saves a lot of time. ......
Tried the wide format option and it's not much use. .......,
I came to the same conclusion when I tried it years ago. I had a wide format Epson and then the Ricoh 3110 doing mugs.
So it appears not much changed.:rolleyes::biggrin:
Our HP stitch is VERY fast at printing, but unfortunately the quality (resolution) is not good enough for hard surfaces, only fabrics
gazfocus
Post by gazfocus »
We looked at going down the route of a wide format coupled with a graphtec cutter at one point but realised it’d be too much hassle. The only advantage would be it could’ve been left to run overnight but then we’d have loads of mug wraps to collect and make sure they were right way round, etc.
We went down the route of a desktop printer (currently sawgrass) and pre cut mug sheets. On a busy day we do about 500 mugs a day and the sawgrass just about keeps up.
JMugs
Post by JMugs »
500 mugs a day would be nice. Having just come back to printing after being away from it for a few years, I have the joy of getting everything up and running again. Why did I ever stop?! :?
