MDP mug press. Read here owner review and pics.
gazfocus
Re: MDP mug press. Read here owner review and pics.
Post by gazfocus »
Rachaelx777;154361 wrote:Hi, how close can you print to the handle with this press?
You’re going to struggle getting close to the handle with any mug press.
Rachaelx777
Post by Rachaelx777 »
The press I currently have struggles with images 2.5 inches wide so just wondering if this one is any better than that. I use the oven usually but looking for a better press for one offs.
gazfocus
Post by gazfocus »
The mug press mentioned in this thread won’t be any good at getting close to the handle. I had a few of these and after a few days the nuts started falling out every so often no matter how tight you do them.
I think the best mug press for getting close to the handle is the adkins mug press that xpres sell but they’re not cheap if you’re just planning on having it as a ‘spare’ and you’ll never get as close to the handle as you will with an oven.
We usually just fill the oven with ‘dummy’ mugs (ie blank mugs that have chips in them) and still run the oven for the full time if we only have a couple of mugs to do.
Rachaelx777
I have this press now and just tried it, the pressure it really tight even with the centre bolt as far back as it goes on an 11oz mug. Is there any other adjustment to be made to reduce pressure?
Has thanked: 13 times
Been thanked: 12 times
As mentioned we bought the press and had the same issue. Just changed mug suppliers and the 11oz mugs are very slightly smaller in diameter and work well in the press.
Bob700
Post by Bob700 »
Hi Justin
Could you give me the name of your new supplier, I use MDP 11oz Orca mugs but they are so tight it's difficult to close the press, I was thinking that 10oz mugs might be better
We've since returned to 10oz XP5013's Xpres.
Bob700
Post by Bob700 »
I use the same press and the pressure is quite light, should I increase the pressure
