Rubbish mugs
Re: Rubbish mugs
I have used the same mugs and paper as you and not had an issue, I use either a dedicated mug press or an oven and not had that issue so .... I would lean it towards being the press, the problem with all in ones they don't always get even heating and often issues with pressure.
Re: Rubbish mugs
Thank you all for your help. It’s been confirmed this morning that’s definitely the press. Thanks ukprintedmugs, I really do appreciate it
Re: Rubbish mugs
[ATTACH=CONFIG]7295[/ATTACH][ATTACH=CONFIG]7296[/ATTACH]
Proper mug has arrived and is absolutely fine !
- vB_ID:7296
- Lollipop Crafts (8 of 22).jpg (32.68 KiB) Viewed 7 times
- vB_ID:7295
- Lollipop Crafts (2 of 22).jpg (37.15 KiB) Viewed 7 times
