Can anyone idenfity this knife holder please? Vinyl Cutter
Re: Can anyone idenfity this knife holder please? Vinyl Cutter
Trying to find a new holder and blade for a machine, suppliers want £60 to ship from from overseas. It's for a Skycut machine.
I'm pretty sure this is a standard holder used across many machines, Roland, GCC, Siser for example. Comparable costs on eBay are £12 for 15 blades and 1 holder!
If anyone uses exact same please let me know. TIA.
[ATTACH=CONFIG]7071[/ATTACH]
vB_ID:7071
vB_ID:7071
I think most of the popular blades are 0.94mm shank diameter. Have you an old blade you can measure?
No, I didnt get the holder or blade with the machine.
Do you know the machine model number Justin? Here are some blade holder sizes for a couple of models ...
[ATTACH=CONFIG]7072[/ATTACH]
[ATTACH=CONFIG]7073[/ATTACH]
vB_ID:7073
vB_ID:7073
vB_ID:7072
vB_ID:7072
Yes, it's the Skycut A3 Max 2, looks like a C Series...yes, as per your first image.
I found them in China but was hoping to get something a bit quicker.
https://www.alibaba.com/product-detail/ ... 13350.html
Mrteajunkie
Has thanked: 5 times
Been thanked: 3 times
Post by Mrteajunkie »
Justin;151837 wrote:Yes, it's the Skycut A3 Max 2, looks like a C Series...yes, as per your first image.
Have you tried a smart knife?
edward Mathias might supply the right one for this and cheaper than holder and seperate blades.
Just looking for a cheap option to test the machine is working perfectly, I've used their knives before and whilst they are excellent they are quite expensive. I can get one from China, just wanted to get on with it.
Mrteajunkie
Justin;151847 wrote:Just looking for a cheap option to test the machine is working perfectly, I've used their knives before and whilst they are excellent they are quite expensive. I can get one from China, just wanted to get on with it.
Ah ok.
I could send you mine if you send it back when your finished if you are just testing it out?
I have a holder for a Roland, graphtec and a us cutter machine if any of those are the right size?
I have smart knives in all My machines so it wouldn’t be an issue.
[ATTACH=CONFIG]7096[/ATTACH][ATTACH=CONFIG]7097[/ATTACH][ATTACH=CONFIG]7098[/ATTACH][ATTACH=CONFIG]7099[/ATTACH]
vB_ID:7099
vB_ID:7099
vB_ID:7098
vB_ID:7098
vB_ID:7097
vB_ID:7097
vB_ID:7096
vB_ID:7096
Would you mind sending me a quick photo of the holders?
Mrteajunkie
Added on the above post for you fella.
blue tip is graphtec
all black is the Roland
black and silver top is the us cutter.
