Can anyone idenfity this knife holder please? Vinyl Cutter
Re: Can anyone idenfity this knife holder please? Vinyl Cutter
Trying to find a new holder and blade for a machine, suppliers want £60 to ship from from overseas. It's for a Skycut machine.
I'm pretty sure this is a standard holder used across many machines, Roland, GCC, Siser for example. Comparable costs on eBay are £12 for 15 blades and 1 holder!
If anyone uses exact same please let me know. TIA.
[ATTACH=CONFIG]7071[/ATTACH]
- vB_ID:7071
- 4056b927-7c2f-454f-a0c3-3cb646cb4eee.jpg (81.51 KiB) Viewed 2869 times
I think most of the popular blades are 0.94mm shank diameter. Have you an old blade you can measure?
No, I didnt get the holder or blade with the machine.
Do you know the machine model number Justin? Here are some blade holder sizes for a couple of models ...
[ATTACH=CONFIG]7072[/ATTACH]
[ATTACH=CONFIG]7073[/ATTACH]
- vB_ID:7073
- Screenshot_20230104-125123_Gallery.jpg (43.69 KiB) Viewed 2869 times
- vB_ID:7072
- Screenshot_20230104-125137_Gallery.jpg (44.43 KiB) Viewed 2869 times
Yes, it's the Skycut A3 Max 2, looks like a C Series...yes, as per your first image.
I found them in China but was hoping to get something a bit quicker.
https://www.alibaba.com/product-detail/ ... 13350.html
- Mrteajunkie
- Has thanked: 5 times
- Been thanked: 3 times
Have you tried a smart knife?Justin;151837 wrote:Yes, it's the Skycut A3 Max 2, looks like a C Series...yes, as per your first image.
edward Mathias might supply the right one for this and cheaper than holder and seperate blades.
Just looking for a cheap option to test the machine is working perfectly, I've used their knives before and whilst they are excellent they are quite expensive. I can get one from China, just wanted to get on with it.
- Mrteajunkie
Ah ok.Justin;151847 wrote:Just looking for a cheap option to test the machine is working perfectly, I've used their knives before and whilst they are excellent they are quite expensive. I can get one from China, just wanted to get on with it.
I could send you mine if you send it back when your finished if you are just testing it out?
I have a holder for a Roland, graphtec and a us cutter machine if any of those are the right size?
I have smart knives in all My machines so it wouldn’t be an issue.
[ATTACH=CONFIG]7096[/ATTACH][ATTACH=CONFIG]7097[/ATTACH][ATTACH=CONFIG]7098[/ATTACH][ATTACH=CONFIG]7099[/ATTACH]
- vB_ID:7099
- CA4616D8-C872-4C6A-B64E-C0EAA051B64E.jpg (52.67 KiB) Viewed 2869 times
- vB_ID:7098
- A5CDD2BF-9D8B-4DAD-BF8D-F403B2AF6845.jpg (25.66 KiB) Viewed 2869 times
- vB_ID:7097
- BC9AF98F-937A-431C-83BB-0B3448CF39E6.jpg (24.46 KiB) Viewed 2869 times
- vB_ID:7096
- E4492324-A5FC-402A-97B2-A0ACADDEA2B8.jpg (21.2 KiB) Viewed 2869 times
Would you mind sending me a quick photo of the holders?
- Mrteajunkie
Added on the above post for you fella.
blue tip is graphtec
all black is the Roland
black and silver top is the us cutter.
