Hi,
I’ve got some Christmas decorations that aren’t sealed on the back like unisub coasters are. The heat tape is pulling the backing off every time. I’ve tried peeling when hot and cold and it still comes off. I also tried less pressure but the image was faded. I’m using Xpres heat tape
Backing coming off
Re: Backing coming off
- vB_ID:7036
- 56C2BE6D-3612-4774-B66D-267ED1CCCAEF.jpg (21.11 KiB) Viewed 581 times
- Mrteajunkie
- Has thanked: 6 times
- Been thanked: 4 times
Looks like a faulty batch to me but then i have no idea what it is supposed to look like.
but the tape pulling it away like that isn’t normal.
- UK Printed Mugs
Two reasons. Either rubbish backing or leave for 24 hours before peeling which is what we do to stop this.
- Has thanked: 13 times
- Been thanked: 12 times
Can you not just tape down onto a sheet? You're wrapping the tape around and causing damage to the rear.
