MDP mug press. Read here owner review and pics.
- Mrteajunkie
- Has thanked: 5 times
- Been thanked: 3 times
Re: MDP mug press. Read here owner review and pics.
Like this. [ATTACH=CONFIG]6700[/ATTACH] [ATTACH=CONFIG]6701[/ATTACH]
- vB_ID:6701
- 7978537D-88B2-4051-8243-C60A67FF20B1.jpg (46.66 KiB) Viewed 680 times
- vB_ID:6700
- C8D528C5-B653-4E82-AEF3-A5AF28B40DC1.jpg (58.19 KiB) Viewed 680 times
its like your picture now but the pressure on the handle when closed is light to medium
- Mrteajunkie
So now tighten the thumb screw.Tony4415;148392 wrote:its like your picture now but the pressure on the handle when closed is light to medium
I have tighten the main screw to a point my fingers now hurts[ATTACH=CONFIG]6702[/ATTACH]
- vB_ID:6702
- IMG_1985.jpg (88.62 KiB) Viewed 680 times
the pressure is nowhere near firm, its light pressure thats why I've release both small screws to get a firmer grip
- Mrteajunkie
Then your element is too big for the mug.
Open the press and tighen the thumb screw.
Close the press
it should be tight against the mug now.
If not then the element is for a larger mug not the 10/11oz mugs.
Close the press
I thought it was the element (c) so I purchased a new one from MPD and its the same
- Mrteajunkie
Element C is the correct one.Tony4415;148397 wrote:I thought it was the element (c) so I purchased a new one from MPD and its the same
measure your mugs across the top how wide are they?
Mine are 79mm for the 10oz
my 11oz Listawood mug is 82mm from the outer rim
Xpres 10 oz is also 82mm
Mrteajunkie;148398 wrote:Element C is the correct one.
I will phone MDP tomorrow and ask for a D element.
I originally asked for a D element and they said its C, thats why I have to release the x2 small screws to get a firmer pressure.
Or it could be the press itself
