9oz Balmoral mug attachment? Do they Exsist?
Re: 9oz Balmoral mug attachment? Do they Exsist?
Hi there,
Forgive if this is a stupid question but I have been a long time lurker and just purchased my first Mug heat press (UK Heat Press from Signzworld).
It comes with a 11oz attachment which is all well and good, but I would also like to heat press onto bone china 9oz Balmoral.
Now, for the life of me I cannot find the attachment to buy for this? Can I use the 110z attachment mat for a 9oz?
I'm sure this is a laughable question if you are a pro, so advanced apologies.
Thanks!
Thanks!
Have you got a link to the Balmoral mug? What is its diameter?
- UK Printed Mugs
You will need a thicker blanket for smaller sized mugs. You should be able to buy alternative mug wraps for different size diameters from suppliers. We have a bank of mug presses all with different size blankets for this very reason.
A standard 10oz Durham mug is 80mm diameter, so a normal '11oz' blanket will be fine.AJG;141025 wrote:Hi Gary It is 94mm tall x 83mm diameter . Thanks
Hi, Thanks for your reply. I do not think the UK heat press has any smaller wraps than 11oz (Would love to be proved wrong)for the press. It was a cheap one so I guess I found its first limitation. I have an oven so will try that way as well. Just for clarification a blanket is the official name for a mug attachment?
Thanks again
Thanks again
Hi, Thanks for your reply. I do not think the UK heat press has any smaller wraps than 11oz (Would love to be proved wrong)for the press. It was a cheap one so I guess I found its first limitation. I have an oven so will try that way as well. Just for clarification a blanket is the official name for a mug attachment?UK Printed Mugs;141026 wrote:You will need a thicker blanket for smaller sized mugs. You should be able to buy alternative mug wraps for different size diameters from suppliers. We have a bank of mug presses all with different size blankets for this very reason.
Thanks again
Great thank you, will be testing this out this week so will publishing my results. Alot of trial and error awaits me..........GoonerGary;141027 wrote:A standard 10oz Durham mug is 80mm diameter, so a normal '11oz' blanket will be fine.
I can't understand why they call these 9oz mugs then. That's the standard size of most 11oz mugs. I always believed the 'oz' stood for fluid ounces, ie. the capacity of the mug.AJG;141025 wrote:Hi Gary It is 94mm tall x 83mm diameter . Thanks
Heat blanket, heat element, mug attachment.AJG;141031 wrote:Hi, Thanks for your reply. I do not think the UK heat press has any smaller wraps than 11oz (Would love to be proved wrong)for the press. It was a cheap one so I guess I found its first limitation. I have an oven so will try that way as well. Just for clarification a blanket is the official name for a mug attachment?
Thanks again
