[ATTACH=CONFIG]5907[/ATTACH]
Hi,
I used a mug press and this is my first time doing it. What did I do wrong? There are patterned lines presumably from heated material from the mug press.
Temp: 330
Time: 60 seconds
Sublimated Mug has lines from heat press
Re: Sublimated Mug has lines from heat press
- vB_ID:5907
- IMG_20190912_222653.jpg (88.01 KiB) Viewed 130 times
We would need more information about the press but yes that looks like the heating element. Have you any photos of the press?
Deffo the heating element. What pressure are you using? I assume that's around 165c? 180c for 180 seconds is a good starting point.
