Mug Bottom Heat Press
Tania
Re: Mug Bottom Heat Press
Post by Tania »
I have seen on the internet you can buy a press to sublimate bottom of mugs, is this available in UK ?
Is there such a machine to sublimate inside also.
Thank you
Tania
You would also need to know that yours mugs are properly coated on the bottom to take the print
Tania;136689 wrote:I have seen on the internet you can buy a press to sublimate bottom of mugs, is this available in UK ?
Thank you
Tania
Just posted about the inside of mugs in this section. Where did you see the machine to print the bottom?
Basically a plate press.
Rubber stamp for mugs, using dishwasher-safe ink...
https://www.etsy.com/uk/listing/6242038 ... tamp-small
[ATTACH=CONFIG]5610[/ATTACH]
vB_ID:5610
vB_ID:5610
Stamp looks interesting, could be hit and miss but possibly worth a shot.
Most plate presses don't seem to have the same opening, unless you remove the base plate I guess. I read about someone digi-coating the bottom and then sublimating with one of these presses, results were very good. A lot of work if you ask me ;-)
Post by GoonerGary »
That stamp looks a bit too 'rustic' . Social's thermo wrap would probably do the job. Perhaps we could form a list of base coated sub mugs?
Yes if rustic is what you need this would work :-) I have thermo shrinky stuff here and will have a go, getting it to go flat over the base may be tricky as it 'gathers' Would be ideal, then they could print at the same time in the oven :-)
