Mug Bottom Heat Press
Re: Mug Bottom Heat Press
I have seen on the internet you can buy a press to sublimate bottom of mugs, is this available in UK ?
Is there such a machine to sublimate inside also.
Thank you
Tania
Thank you
Tania
You would also need to know that yours mugs are properly coated on the bottom to take the print
Just posted about the inside of mugs in this section. Where did you see the machine to print the bottom?Tania;136689 wrote:I have seen on the internet you can buy a press to sublimate bottom of mugs, is this available in UK ?
Thank you
Tania
- UK Printed Mugs
Rubber stamp for mugs, using dishwasher-safe ink...
https://www.etsy.com/uk/listing/6242038 ... tamp-small
[ATTACH=CONFIG]5610[/ATTACH]
- vB_ID:5610
- il_fullxfull.1544916838_n77y.jpg (82.85 KiB) Viewed 416 times
Most plate presses don't seem to have the same opening, unless you remove the base plate I guess. I read about someone digi-coating the bottom and then sublimating with one of these presses, results were very good. A lot of work if you ask me
That stamp looks a bit too 'rustic' . Social's thermo wrap would probably do the job. Perhaps we could form a list of base coated sub mugs?
Yes if rustic is what you need this would work
I have thermo shrinky stuff here and will have a go, getting it to go flat over the base may be tricky as it 'gathers' Would be ideal, then they could print at the same time in the oven
