Ricoh set up ? I’ve been a numpty
Dollshousegirl
Re: Ricoh set up ? I’ve been a numpty
Post by Dollshousegirl »
Have I killed my printer, before I even start? I purchased a Ricoh SG 3110 DN and like a numpty..unpacked it plugged it in put in the cartridges and turned it on......... THEN ..l decide I’m gonna look at the instructions - it capitals there’s this
DO NOT POWER ON THE PRINTER BEFORE INSTALLING SAWGRASS SUBLIJET-R INK CARTRIDGES.
obvs my cartridges are now showing as empty.
I’ve rechecked the box, no set up leaflet, and no usb cable to connect.
i rang the company first as I thought they’d sent empty cartridges, then delved a bit deeper and realised I’d not done set up correctly. I’m waiting for a call from their tech guys next couple of days
so my question is .... have I completely f#%@$d my printer or is there a way out
Firstly, most printers don't come with a usb cable. This has been the case for many, many years.
Secondly, when you first install cartridges the Ricoh uses a LOT of ink to initially fill the long supply lines leading to the print heads. Once it's been primed you'll find the Ricoh is very economical on ink use.
Just to confirm, it is the sawgrass carts you've installed?
Dollshousegirl
It’s these I have -
vB_ID:5562
vB_ID:5562
Earl Smith
Post by Earl Smith »
I would imagine you bought this printer from one of the suppliers on here as they have supplier Sublisplash inks, which are very good.
Give the supplier a ring and they will sort you out. I dont think the printer is kapputt.
Dollshousegirl
You are an absolute star ... I rang them Friday but as I got it late Friday ... tech
team were due to ring me ... I’ll give em a ring again tonight ... it was dye sublimation.co.uk
thryve got a good unboxing printer vid on YouTube ... why oh why I didn’t watch that first
Earl Smith;136512 wrote:I would imagine you bought this printer from one of the suppliers on here as they have supplier Sublisplash inks, which are very good.
Quinsfan
Post by Quinsfan »
Be aware that most of the team are at the Printwear and Promotion show today and tomorrow. I know Adam is as I was chatting to home yesterday and he is the main technician.
