Looking for an A3 Printer
2017crafter
Re: Looking for an A3 Printer
So I’ve perused the forums and understand that the easy route into sublimation would be RICOH or Sawgrass. I want an A3 printer primarily for text on cushions but I’ll be making mugs etc too. I don’t really have a set budget. I’d rather buy quality and something easy to use with support than cheap and difficult. Currently have ciss on my normal inkjet and it’s been a pain to sort once air bubbles got into tubes. BUT I want to buy a vinyl cutter at some point (and a mug press) so don’t have a bottomless pit of money so to speak. What are my choices?
thanks in advance.
thanks in advance.
DyeSubSupplies
We have the following A3 printer in stock at the moment link below also if you want to bundle it together with the other items you looking for i'm sure we can sort a deal out for you.
https://www.dyesublimationsupplies.co.u ... splash-Ink
2017crafter;132891 wrote:So I’ve perused the forums and understand that the easy route into sublimation would be RICOH or Sawgrass. I want an A3 printer primarily for text on cushions but I’ll be making mugs etc too. I don’t really have a set budget. I’d rather buy quality and something easy to use with support than cheap and difficult. Currently have ciss on my normal inkjet and it’s been a pain to sort once air bubbles got into tubes. BUT I want to buy a vinyl cutter at some point (and a mug press) so don’t have a bottomless pit of money so to speak. What are my choices?
thanks in advance.
Speak with Ink Express about the Epson P600 with Inktec Sublinova ink with either ciss or refillable carts (29mml capacity)
Don't know if they have the necessary 2 light blacks yet.
A3+ 8 colour printer with much lower ink costs.
2017crafter
Just a thought, what size are the cushions? Just check A3 will be big enough, bear in mind you won't get edge to edge so A3+ may work for you if required.
P600 package has just been released I believe, I've seen the results and the print is absolutely superb. Ricoh is an option if you want to work with carts but CIS is easy enough.
- UK Printed Mugs
We may be selling an SG7100DN A3 Printer shortly I believe. Let me know if interested but when I officially know I will post up on for-sale section.
- InkExpress
Hi Jimbo, yes P600 is now released for sale, we have all the correct Sublinova Inks for it (Black, Light Black and Light Light Black)Jimbo;132895 wrote:Speak with Ink Express about the Epson P600 with Inktec Sublinova ink with either ciss or refillable carts (29mml capacity)
The printer complete with 900ml of ink is currently £799.00 Inc. VAT, 900ml ink refill sets will be £80.00 Inc. VAT or individual colours / 100ml are £10.00 Inc. VAT
https://www.ebay.co.uk/itm/None-OEM-A3- ... Swpe1bLNUV
Thanks Justin, pleased to hear you liked the results from the test prints we sent up to youJustin;132902 wrote:Just a thought, what size are the cushions? Just check A3 will be big enough, bear in mind you won't get edge to edge so A3+ may work for you if required.
Alex
2017crafter
i think I’ll stick to A3 because I’m just starting out and anything bigger will be expensive. Would love to see the P600 in action but nothing close to me at the moment.Justin;132902 wrote:Just a thought, what size are the cushions? Just check A3 will be big enough, bear in mind you won't get edge to edge so A3+ may work for you if required.
2017crafter
ill watch out for it if I haven’t made a purchaseUK Printed Mugs;132903 wrote:We may be selling an SG7100DN A3 Printer shortly I believe. Let me know if interested but when I officially know I will post up on for-sale section.
2017crafter
What’s the advantage of the Reveal package over the p600 standard set up? Both suppliers are super helpful
