Newbie needing a little help and guidance
Gabby_S
Re: Newbie needing a little help and guidance
Post by Gabby_S »
Think I've missed a setting.
Print came out very red after pressing at 190 for 60 secs.
Printed with Ricoh 3110dn.
All help gratefully received.[ATTACH]5318[/ATTACH]
Sent from my SM-G920F using Tapatalk
vB_ID:5318
vB_ID:5318
Quinsfan
Post by Quinsfan »
Printer, inks, heat press, icc profile??
Gabby_S
Post by Gabby_S »
Quinsfan;132880 wrote:Printer, inks, heat press, icc profile??
Ricoh 3110dn, refillable ink cartridge with highly recommended ink.
None branded heat press set at 190° pressing for 60 seconds.
Need advice on how to use/set ICC profiling.
Any helpful advice welcome.
Quinsfan
Post by Quinsfan »
Your ink supplier should be able to give you an ICC profile. Without this you will struggle to get the colours your want
What ink are you using?
