Jet opaque 3g and vinyl layering
paul 44
Re: Jet opaque 3g and vinyl layering
Post by paul 44 »
Hi folks, Ive done a few shirts where I've printed a 3 color logo using 3g jet opaque, over the top of that and out with the logo is mdp hotflex vinyl, the customer has come back and said that the lettering has came off, anybody else had this happen?
paul 44
Post by paul 44 »
here is an image of the shirt and where the lettering has came off
vB_ID:5027
vB_ID:5027
duff tshirt.jpg (94.78 KiB) Viewed 20 times
paul 44
Post by paul 44 »
here is another image of another shirt, the vinyl has adhered to some parts but not others as you can see from the 2 images
vB_ID:5028
vB_ID:5028
duff shirt 2.jpg (96.18 KiB) Viewed 20 times
paul 44
Post by paul 44 »
Would this be a vinyl issue, I have spoken to the suppler and they said that various colors of vinyl are made my different manufacturers so this may be the problem with the adhesive?
paul 44
Post by paul 44 »
I've also changed the heat platen on the press, more or less brand new plate just in case its the platen that isnt heating properly
paul 44
Post by paul 44 »
Has anybody had this problem at all because i've done it before and not had a problem?
paul 44
Post by paul 44 »
Well i've just spoken to mdp and they advise that hotflex isnt suitable for layering over Jet opaque 3g due to the ink layer, i've never seen this happen before?
If that is the case then what would be the best way to get around this problem with an intricate design like that?
Ricky@Xpres
Post by Ricky@Xpres »
Hi Paul
We only ever recommend layering the same product. Manufacturers test that the same vinyl layers without any issue but different medias react differently in the wash and have different coatings or are covered in solvent ink - so it would not be possible to test adhesion to every media on the market.
Have you tried printing the job in one go and back weeding the intricate detail ?
We also have a printable media (Solvent Dark Turbo)with a tacky backing that might help with the intricate detail. If you PM me your details i will arrange a sample to be sen out.
I hope this helps
Ricky
Xpres
