pale subbing
robhil
Re: pale subbing
Post by robhil »
I am having real problems at present.
I was subbing glass clocks, coasters, key rings etc with no problem.
I bought a purse from Isub supplies and followed their advice about printing and pressing.
This came out of the printer fine but was very pale after pressing.
I decided I would try pressing again with a much darker print to try and cover up the original, however it still came out very pale.
Any ideas what I am doing wrong.
vB_ID:4631
vB_ID:4631
Re: pale subbing
Could be a number of things, first that springs to mind would be press, are you getting a good even heat without cold spots?
Re: pale subbing
do you set your press to Celsius values but press is in Fahrenheit?
robhil
Re: pale subbing
Post by robhil »
Justin just had it serviced at adkins replaced alot of parts but have said it is now as good as new.
Paul I haven't done anything different to what I have always done, Its almost as though the paper is not releasing the ink.
Re: pale subbing
wrong side of paper?
Re: pale subbing
Yeah, double-check your paper is the right way up. Believe me, it happens!
robhil
Re: pale subbing
Post by robhil »
What a thicko am I
The paper was the right way round but I loaded it onto the press paper on the bottom instead of on the top, tried it this morning and came out fine.
Sorry to trouble anyone.
