Sublimation not transfering image
sanelhen
Re: Sublimation not transfering image
Post by sanelhen »
Hi what could be the problem if the heatpress dont transfer the image. I have check videos and im doing exactly the same putting transfer paper on the product with image facedown. 190 celcius for 60 seconds??? PLEASE HELP?
Sent from my SM-A310F using Tapatalk
We have no idea about your set up. Your paper ciuld be not sublimatikn paper or inks could be nit sublimatikn inks.
...or you try to print on none sublimation item.
cyprian.costelloe
Post by cyprian.costelloe »
Check your are printing on the correct side of the paper
Sent from my HTC One_M8 using Tapatalk
Benberg
Post by Benberg »
cyprian.costelloe;119833 wrote:Check your are printing on the correct side of the paper
I could be wrong but I believe you would still get a transfer, even if not a perfect one, if the print is on the wrong side of the paper?
cyprian.costelloe
Benberg;119843 wrote:I could be wrong but I believe you would still get a transfer, even if not a perfect one, if the print is on the wrong side of the paper?
You get a very weak image sometimes, depends on the settings.
Sanelhen
As you have not responded to the answers on this thread you have either sorted it or given up (it would be nice to know either way). If you are still looking for an answer then please give the following details:
Printer make and model
Ink manufacture and where you purchased it
Press make and model
Where you purchased the blank from
Without the above it is very difficult to answer your question, this forum is free and people give up valuable time and knowledge to help you, please help them to help you.
sanelhen
Post by sanelhen »
socialgiraffe;119854 wrote:Sanelhen
Hi
The ink is from bulk ink south africa. Printer using ricoh. Using sublimayion paper from custom signs and graphics south africa. Heat press from bizinbox south africa.
Sanel
sanelhen
Post by sanelhen »
sanelhen;119916 wrote:Hi
Receiving new blank stock tomorrow that I can test again
Sanel
daviddeer
Post by daviddeer »
makes me wonder if this is standard ink and not sublimation as everything else seems to be in order. Or perhaps the substrate is cotton.
pw66
Post by pw66 »
How accurate is the temperature setting on your press? I have a Stahls press that shows 200c when it is only at 145.
Temperature is critical. At lower temperature the ink won't turn to gas so you will get no sublimation. I would get a thermometer and take a reading of the platen heat.
Users browsing this forum: Semrush [Bot] and 5 guests
