Just did a shirt with this and getting bleed through, shirt is red and has tainted the print which was done on 3g opaque, guideline state that 3g is ok for this material but obviously its not.
Thinking that if I get another transfer film I may be able to print a larger logo and print over the 3g logo, any ideas on what transfer film to use?
3G opaque and 100% poly
JjcCustomTs
Re: 3G opaque and 100% poly
Try splitting your press time (15 seconds, let the press up, wait a few seconds and press another 15 seconds). I was having the same issue and tried it that way. It worked for me. I've also heard d people that say lowering the temp and increasing the press time worked for them.
I spoke to yolo after the fact and they told me to do that also so I may try that next time on the poly shirts.
tried the 15 seconds and im still getting bleed through from the garment, should I drop the temp on the press, i'm pressing at the standard 175, these are dri fit shirts in printing onto 95% poly
Can I use 3g jet opaque through my ricoh 3110dn for the poly shirts or is this a no no??
