Hi Guys can anybody please give me some advice on a power problem i am having with my 3d vacuum press.
I have just purchased a machine plugged it in but the lcd display is not lit up and there is a beeping noise coming from the machine.
Is there something i should be doing to stop it or could this be a fault indication noise?
Any help with this would be appreciated Thanks Brian
3D Mini Vacuum press problem
Re: 3D Mini Vacuum press problem
Is it ST 3042 ? If yes, first contact someone from Sunmeta (the manufacturer) to have confirmation as for the problem, and in this case you can directly buy spare part from them.
I have their contact details (email/whatsapp) as well as their pricing list for spare parts (they are relatively cheap). PM me if you need them.
Hi thanks for your help, no its not the model you said,its model no st-1520
Yes same procedure, contact them and if they confirm it's a lcd/other problem just buy spare part.
