Printing on hi vis
Re: Printing on hi vis
Anything I achieve I learnt on here for ten quid a year:biggrin:
Sublimation works qwell if you're doing a nice solid black. Vinyl will also work well and if you're worried about melting a lower temp vinyl would be good.
I find hi-vis is ok but can bleed a little at higher temps so use a cover sheet.
Thanks Justin, that's worth a tenner right there
Dave271069
might be worth considering the reflective high viz EN471 stuff it really pings when in low light situations and gives advanced warning puts the price up a lot though.
