Virtuoso SG400 print colours very dull
Re: Virtuoso SG400 print colours very dull
I am very disappointed with the colour I am getting from my printer, very dull, nothing like the colour from my HP inkjet printer. I have done a head clean but still horrible. How can I set up the colours?
- UK Printed Mugs
I presume you mean post pressing? The colour on paper is very different to what will be sublimated onto a substrate.
Thanks, I was afraid that was the problem, will try again tomorrowmalkram;115025 wrote:You must use PowerDriver software
You did fail to mention if pre or post pressing... If you are looking at the paper pre pressing then they are horrible. Press onto an item and the check what the image is like.
I am using Creative Studio Print & Colour Manager. The image on the computer screen is bright and colourful but when I print it onto TexPrint-R is dull and lacking colourmalkram;115025 wrote:You must use PowerDriver software
- vB_ID:4197
- IMG_20160912_1338458.jpg (92.05 KiB) Viewed 441 times
- vB_ID:4196
- Reflection-001.jpg (104.26 KiB) Viewed 441 times
I used to use TruePix paper, maybe TexPrint is not suitable for this, I truly don't know. That's when you print or when you press ?
The righthand image is printed prior to pressing, I am using the paper supplied with the printer. I have done a head clean and all the cartridges have ink.malkram;115048 wrote:I used to use TruePix paper, maybe TexPrint is not suitable for this, I truly don't know. That's when you print or when you press ?
......so, have you tried pressing yet? Personally I would suggest Truepix all the time.
- UK Printed Mugs
I believe two things about Power Driver 4. Firstly it is set up for Truepix paper and as Justin says then this is the best to use anyway. Other papers may show different results. Secondly, PD4 is rubbish in our experience and never gets the colours correct. Hence why if you are serious you need to head down the custom ICC profile route.
