Where do I stand?
technick
Re: Where do I stand?
Post by technick »
My heat press has packed in (BMS DF20) - electrical fault, all lights on LCD is flickering and sometimes not even turning on. Tried with 4 different cables. The high pitched beeping sound is not flat also Does this fault typically get covered under warranty? It's only 6 months old. Cheers:)
What did supplier say? I would expect at least 12 months on the press, usually the exception is with the element.
logobear
Post by logobear »
trade products don't have the same inplicit guarentee that consumer goods do ..... so you don't automatically get any warranty.
If you bought it from a reputable supplier I am confident you will be covered (thou probably not for transport either way) but if a cheapo off flea bay, you are almost certainly on your own.
Good luck!
Sorry, I assumed you had bought new?
technick
Post by technick »
BMS have been great. Scotty has sent out a new control unit today at no charge - cannot ask for better service than that, hopefully it resolves the issue:)
ArferMo
Post by ArferMo »
There ya go...... a quality supplier
