New Workshop
Re: New Workshop
Hi all.
haven't posted for sometime due to other commitments and with getting myself out there to promote what we do. have to say that so far we have been doing pretty well. No major issues so far, although I'm still trying to find the time to teach myself how best to print onto latte mugs wthout distorting the images.
Just thought I would take the time to share some images of my new workshop that I'm currently building. 14' x 10' in case anyone is wondering.
- vB_ID:3946
- 12688011_10205158535555028_9096401244188904421_n.jpg (89.91 KiB) Viewed 388 times
- vB_ID:3945
- 12742663_10205264591446359_1544513763032531851_n.jpg (15.34 KiB) Viewed 388 times
- UK Printed Mugs
Re: New Workshop
Fantastic! Very impressive. Hopefully getting power won't be too much of an issue. Ideally you need to take it off a separate breaker from your consumer unit or if not possible then a properly installed fused spur just inside the house where your cable will come from. Obviously don't use a long extension lead!
mags1892
Re: New Workshop
Im looking at doing same what thickness and type of insulation are you using I was looking at 100mm of Kingspan all around
Re: New Workshop
mags1892;110888 wrote:Im looking at doing same what thickness and type of insulation are you using I was looking at 100mm of Kingspan all around
It's 4x2 framing inc the roof with Kingspan insulation panels in the floor & roof. Walls will be rockwool insulation. There will be a permanent seperate feed from the main consumer unit. Did consider using sips panels but opted for the 4x2 framing for ease of feeing the mains & lighting circuts. total cost to date is in the region of £1600.00. Wood and kingspan from a local mill, with the french doors and window costing £65.00 for the 2 on ebay.
Re: New Workshop
Nice, keeps things all out of the way. Just wondering if the other one (Green, red and yellow) is your current workshop........
Chuckle, chuckle...
Chuckle, chuckle...
Re: New Workshop
Thats the expresso mugs and keyrings dept.JMugs;110908 wrote:Nice, keeps things all out of the way. Just wondering if the other one (Green, red and yellow) is your current workshop........
Chuckle, chuckle...
Re: New Workshop
For latte mugs you need to arc the design, your supplier of blanks should be able to provide you with this
Re: New Workshop
socialgiraffe;111010 wrote:For latte mugs you need to arc the design, your supplier of blanks should be able to provide you with this
I have all the templates from Listawood. Problem is finding the time to play with the designs so that they fit. Have dabbled a bit with them but Listawoods template for the latte is not scaled to 100% so getting the scale just right is the stumbling block.
Once I get the time, I'm sure I'll get it spot on.
Re: New Workshop
Still trying to convince the other half to let me build 10 x 20, (would be partitioned to be a shed 10x6 shed, and the rest for my bits)
We were advised when you run your power cable, run a spare, non connected cable at the same time,
If for any reason it ever suffers damage you can connect the second cable up without the issue of pulling through etc. Especially as we were looking at digging concrete to run cable in the first place.
