artwork help (engraving)
jennywren
Re: artwork help (engraving)
Post by jennywren »
I do engraving and would like to put the images on our website, but if I take a picture of a lighter the image is blighted by light bouncing of the lighter, I've scrubbed around that and trying for a different approach, I want to put the image of the engraving but need to be a reasonable picture but also of a low quality that they can't copy it as the line drawer I have done take hours to do.
You will need to bounce off the flash of the sealing or back wall. Otherwise you will only get dark image with flash flare in it
jennywren
Post by jennywren »
Paul;106645 wrote:You will need to bounce off the flash of the sealing or back wall. Otherwise you will only get dark image with flash flare in it
I going to take pictures of the line drawing and put it next to the zippo, tankard, glass and anything else that I engrave, this way it will save me engrave all the items that I do, the same image can on various things so I've decided to take a image of my line drawing to show what it would like. But I don't want the image to be clear to be copied.
daviddeer
Post by daviddeer »
Try slicing the image in photoshop or fireworks and importing the html.
