HELP!!!! - Problem with WoW 7.7
Gygafo
Re: HELP!!!! - Problem with WoW 7.7
Post by Gygafo »
Earl Smith;104039 wrote:Hi Nigel, can Yolo Dark print 100% white? Thats what WoW is for.
Hi Earl, Yes it does, I've been using it with my Oki C711WT for the best part of a year now.
Cheers!
Nigel.
Earl Smith
Post by Earl Smith »
Interesting. Is Yolo dark the Forever paper (Forever Dark) and what is the price compared to WoW? WoW costs 120€ for 50 sheets.
Stitch Up
Post by Stitch Up »
Any pictures of finished products?
jennywren
Post by jennywren »
Gygafo;104037 wrote:Hi Jenny, I gave up with TMT's WoW paper in the end as they couldn't resolve the continual problem I was having. New firmwear for the printer, new batch of paper, even the area sales manager tried it at my place and it wouldn't work for him either. I use Yolo Laser Dark paper and it has a 100% hit rate, not one failure! It peels apart like pulling grease proof paper away from hot butter... real easy and no messing about. It also washes miles better than TMT's WoW too. TMT wanted me to try a box for free... I turned it down as I've lost all faith in the product. Don't get me wrong, I still use TMT products but just not their WoW paper.
Cheers!
Nigel.
I am bit nervous about that happening, I have spent a fortune and debated between two thing and settle for wow.. Did you have their press and printer, what was the problem. I have used wow.7.5 but on a different printer and got on alright with it. What do you use the printer for now. I am really nervous about tomorrow.
Gygafo
Post by Gygafo »
Stitch Up;104046 wrote:Any pictures of finished products?
I can post some pictures but it will be on Wednesday as I am trying to get a large order out by then, I was pressing t-shirts till 10:30 last night and will probably be the same tonight. :) Happy day's!
Gygafo
Post by Gygafo »
jennywren;104048 wrote:I am bit nervous about that happening, I have spent a fortune and debated between two thing and settle for wow.. Did you have their press and printer, what was the problem. I have used wow.7.5 but on a different printer and got on alright with it. What do you use the printer for now. I am really nervous about tomorrow.
Hi Jenny, Everything was from TMT but like I say, I still use their other products just not the WoW paper. They have a new formula for this latest batch that may be just fine but I'm sticking to Yolo. Oh and cost wise, Yolo is about £122.00 inc vat and delivery.
Cheers!
Nigel
ArferMo
Post by ArferMo »
@jennywren any update yet ?
jennywren
Post by jennywren »
Very successful and well worth the wait. One of the suggestions that he id say about it being hot to peel back was to buy the rubber thimble ( I think they use them for counting money )to use one on the finger holding down the paper and that will take some of the heat, I've had a few tries since he's left and each one perfect. So any mistakes from now are down to me as it works so if turns out a mess that means I've made a mistake and its not the paper or press. Alan form Magic Touch was a excellent ambassador of them. I'm glad that I can do it as in a moment of foolishness I accepted a very large order from a company which I more than confidant to do
Gygafo
Post by Gygafo »
Nice one, glad all went well and you are pleased with the result. The last box I had wouldn't hold the toner, it flaked off when the paper was picked up from the back of the printer and when TMT couldn't explain or remedy the problem I switched media as it was getting too expensive to carry on.
Good luck Jenny.
Cheers!
Nigel.
jennywren
Post by jennywren »
Gygafo;104069 wrote:Nice one, glad all went well and you are pleased with the result. The last box I had wouldn't hold the toner, it flaked off when the paper was picked up from the back of the printer and when TMT couldn't explain or remedy the problem I switched media as it was getting too expensive to carry on.
Good luck Jenny.
Cheers!
Nigel.
It nice to know that you could transfer to Yolo dark print as alternative, I didn't realize that you could put other paper their Magic Touch printers, is it as much faff with the Yolo paper as it is with wow 7.7. I really did like the wow 7.5 paper I really got on and that was a bigger faff that wow 7.7. Its always a gamble when you do new things even from a reputable dealer, I have a couple more expensive items I need to buy soon and still get nervous where I order from. Because if we get it wrong there is no getting your money back
