SG3110DN problems with photoshop
Re: SG3110DN problems with photoshop
Hi all
Hopefully someone can shed some light on this
I have Ricoh SG3110dn all set up and working but having some issues with prints
Company I bought from have been really helpful, they have even done a print using same inks,profile and paper and sent to me
I am happy that that side of things is ok, my question really is
They use coral paintshop pro x7 and have sent me the settings for that
I downloaded trial version and mirrored their settings, there is a big improvement
I am a photoshop user so would prefer to be able to work through that but when i print using what i believe are the correct settings the image quality is a lot worse
The icc profile they have sent me seems to put a mask over the images, this icc is tested and working profile
I am at a loss now
Does anyone use standard settings and get good results, if so can you possibly let me know what you are set at
I have tried 4 different paper types, papers I have had good results with using a far inferior printer
Any help or advice is much appreciated
I am at a loss now
Photoshop & powerdriver works for me, a screen shot of my settings in P/S
- vB_ID:3634
- screenshot1.jpg (41.67 KiB) Viewed 41 times
Thanks Scotty
The inks I have are not sawgrass will that make a difference?
Aha, sorry mate I'm 99% sure it will, so not much help am I
You responded so yeah you have been helpful
I have asked the compnay i bought printer from if powerdriver will help
It is weird how they use everything same as me (but in paintshop pro) yet the results are so different
I run my Ricoh using an ICC profile so my photoshop print screen looks like this:
If you use an ICC profile as above, also change the printer preferences: color profile needs to be off.
Go printer preferences, choose user settings. then set "color profile" off.
Karen
Karen
- vB_ID:3636
- Capture.JPG (46.95 KiB) Viewed 41 times
- vB_ID:3635
- Capture3.JPG (45.69 KiB) Viewed 41 times
I have just done a test with powerdriver and the results on paper seem to be much much better, will know more when i do a press
Thanks for that info Karen I will make sure i have it set right pretty sure i have already but will run a double check and test
Thanks to you both for your replies and advice very much appreciated
Checked the printer settings they were correct, looks like power driver has sorted it, will be pressing later so will update
Thanks again
Thanks again
Remember the print will look dull on paper, but should be clear when pressed
Yeah cheersscotty44;103448 wrote:Remember the print will look dull on paper, but should be clear when pressed
Even on the paper the print is so much better
Finally seem to be getting somewhere
Thanks again
