Mug Press issue
cherrydesigns
Re: Mug Press issue
Post by cherrydesigns »
Hi Guys,
I've an old upright x-press mug press and no matter what I try, the print fades in the at the ages. I've adjusted pressure, moved the artwork. I'm next thinking is the heat element & not sure where to buy one as it's fairly old.
Can anyone advice?
Kind Regards
Richard
Cherry Designs
Tel: 01793 781662
JMugs
Has thanked: 10 times
Been thanked: 10 times
Re: Mug Press issue
Post by JMugs »
Quick search will sort that out for you.
Not being difficult, just it's all here. search "full wrap"
cherrydesigns
Re: Mug Press issue
So had a butchers around. Are we say the general advice is to leave the transfer paper on and press again or for longer period. What's the recommended temp and time for mugs?
Kind Regards
Richard
Cherry Designs
Tel: 01793 781662
KathG
Re: Mug Press issue
Post by KathG »
Hi Richard, I do my mugs at temperature 180c for 180 seconds. How my press works is you put the mug in when the temperature reaches 170c it then drops a little, once it gets up to 180c it starts the countdown. So in reality the mug is in the press longer than the 180 seconds.
Cheers
Kath
Cheers
Kath
cherrydesigns
Re: Mug Press issue
Hiya, Thank you - my press, is set to 180c for 180 secs and its just near the handle to print fades..
Kind Regards
Richard
Cherry Designs
Tel: 01793 781662
KathG
Re: Mug Press issue
Post by KathG »
On my mug press I have stop the design at least a half inch in fact it will be a little more from the handle, otherwise I will get fading.
Cheers
Kath
Cheers
Kath
cherrydesigns
Re: Mug Press issue
vB_ID:3600
vB_ID:3600
vB_ID:3600
vB_ID:3600
vB_ID:3600
vB_ID:3600
vB_ID:3600
vB_ID:3600
Kind Regards
Richard
Cherry Designs
Tel: 01793 781662
KathG
Re: Mug Press issue
Post by KathG »
Hi again. Umm the design looks enough away from the handle. The black looks ok too. The only thing I can think of is pressure and making sure your paper fits tightly around the mug. Up to now the only time I have that problem is if I get the design too near the handle.
Hopefully someone else will chirp in with some other ideas.
Cheers
kath
Cheers
Kath
cherrydesigns
Re: Mug Press issue
Hiya, thank you - I setup the colour profile just fine, that sorted that. I also did some test runs and it came out fine, however. I've realised that if I do like these photos, it comes out just about okay.
vB_ID:3604
vB_ID:3604
Kind Regards
Richard
Cherry Designs
Tel: 01793 781662
Users browsing this forum: Google [Bot] and 4 guests
